itiswhatitis1
- Feb 1, 2013
- 3
The engine wont idle when I start it cold but once i rev the engine for over 10 minutes it will eventually idle on its own when it warms up. Any suggestions on how to correct?
Does this motor have the prime start enrichment system?
Model # would help some one look that up.
If so your system needs attention along with the carbs.
possibly cleaning all passages and check diaphragm.
Readjust like manual calls for after reinstalling.
Never hurts to check compression,spark, and timing to make sure motor is healthy
Might check on fuel pump to make sure it does not have a pin hole
