drumbeater
- Aug 17, 2004
- 15
I been working on this thing for a few weeks. I think its an 86 model but not sure. I've rebuilt and had ultrasonic cleaned carbs, fuel pump has new parts, new plugs, new fuel.
I pull and pull and pull and the sparkplugs stay dry. I've got spark. Bowl in carb is full of gas. There is just no gas going to the sparkplugs, they stay dry as a bone. Just a little residue from old oil and some seafoam I sprayed in there to loosen things up.
Compression is 100 in top cylinder and 120 in bottom. Not perfect, but good enough for it to run I would think.
I will say I have no wiring diagram, so I assume all wires are connected, but if the plugs are dry that really doesn't matter, right??
HELP! I'M ABOUT TO THROW IT IN THE DUMPSTER.
Thanks,
DB
Thanks,
DB
