nautique95
- Jan 3, 2013
- 7
Hello, all. Here is the story. I have confirmed with a timing light the engine is missing on cylinder 6 but only below about 1500 rpms. It is especially noticeable under load. Once you hit a certain speed, it all sparks and runs perfectly. I exchanged the ECU (powerpack thing) from Cylinder 6 with the cylinder directly above it. The no-spark symptoms remained on cylinder 6 and did not follow the ECU. That would lead me to believe that the ECU is just fine and that something else is the culprit. I cleaned the grounding points that I could see and still same issue. Other cylinders could possibly be missing as well, but I believe it is just #6. Any guidance as to why it may be missing would be greatly appreciated. Thanks!
Jake
Jake
