My 225 tilt trim motor runs by its self in the down direction. The only way to stop it is to turn off the battery. when you turn the battery back on it works fine in both directions. This may happen again later in the day or it may not occur again for a week. Where is the relay, I can't find it in the parts lookup. I feel it must be a relay problem because it stops with the battery off like the relay is releasing.
