I have a 1988 Suzuki DT65 with monitor gauge 34701-92x50. The gauge has water flow light, oil level light (three green and one red), oil lamp light, rev limit light. Engine was running great on water when the red oil level light came on but the three green level lights were on also. Bottle was full of oil. The engine went into limp mode and would not reset.
I have changed the oil level sensor, oil flow sensor, oil reset switch, CDI, Throttle position sensor, carbs rebuilt this year. I have checked the wiring harness. Anyone know if the red light below the three green for oil level is supposed to be on during normal operation? Maybe bad monitor??
