drumbeater
- Aug 17, 2004
- 15
I've got great spark, new fuel, but plugs stay dry. Bowl fills on carb, cleaned the carb several times. Fuel pump looks ok but I'm thinking the motor should at least start with primer pressure even if the pump was bad.
Compression is low in one cylinder but that's with a totally cold engine. It's still over 70psi. Other cylinder is around 100psi.
Any ideas? I know nothing about the CDI on this motor but figured spark meant it was ok.
