Sir 99yam40. I changed the damper exhaust seal. the tell tale stream is still pulsating.The water pressure guage read 5 lbs at idle,(with ear on from graden hose),them when you go to higher r.p.m.'s the guage needle goes up and down.(pulsating. Try a new water pressure guage still does same thing.I have been told to pull the cylinder cover and wire brush the jackets? please help Buddyz/28
