Re: 1997 pro v yamaha water pump problem
Thanks 99yam40.Yes i am talking about the water pressure guage sorry.I get a stream out the tell tale hole,but its not a steady flow.it pulsating.I will drop the lower unit and ck the impeller were it slides on key.Also change the damper seals.I will do it on the 31th,and let you know Thanks again buddy
