I can trim up the engine with either the button on the clutch or the button on the engine; however, if I use the button on the engine to trim down the engine it blows the 30 amp fuse. Also the down button on the clutch doesn't respond. The 60 amp fuse has been replaced and a 15 amp fuse in the console has also been replaced. Any idea what is causing this?
