Blizzaed121212
- Oct 9, 2012
- 1
My 2004 Suzuki 250 will not return to idle from running speed. Usually it will go down to about 1800 to 2000 RPM and then I cannot pull the lever back beyond that point and it is still in gear. In order to shift into neutral I have to shut it off, pull the lever back and restart. Most of the time when I restart it will return to normal idle and shifting. The problem returns when I go into forward and boost the throttle to running speed and then try to return to idle. This motor has about 150 hours on it.
