Ok, thanks for any input. Son installed a stereo system in boat. He is not a pro by any means. My 89 model 130 ran flawlessly the same morning. Son spent all night under dash etc. installing amp and stereo. He said a couple of times he did get a slight spark from some wires near back of gauge cluster etc.
Problem now - engine was untouched, now no spark. He messed just with wires by yamaha gauge cluster and shifter control.
What still works 100%
1. engine cranks and spins perfectly by turning ign. key
2. Electric Choke mechanism chokes carbs when depressed
3. Tilt works fine
4. Neutral safety works fine by not allowing cranking unless in neutral.
5. Gauge cluster is working.
What does not work - NO SPARK TO ANY CYLINDERS
fuse on side of engine is good.
again all work was done up front (gauges and shifter), engine ran perfect that morning.
HELP??
3. Tilt works fine
HELP??
