I'd stay with Stabil Marine, Seafoam and Yamaha Ringfree, but if your carbs are in fact plugged up, then chemicals may not take the place of carb cleaning. Have you tried draining each carb with float chamber drain screw? Do you have a fuel/water separater type fuel filter?
I have a 1998 Yamaha 150hp outboard, can I use STP gas treatment to clear the carbs....it's running a bit rough after fresh fuel this weekend?
