I have a OX66 200hp Yamaha. I have a basic Yamaha multi-function Tac that came stock with this motor. Just prior to re powering, I installed new Faria gauges in the boat. I hooked up the water pressure gauge and now want to use my temp gauge but can't seem to figure out where to attach the temp wire to my OX66. Does this motor have a sender that will run a gauge or only a sender for an alarm application. Given the motor has a sender and that the gauge has the correct resistance range I am assuming that it will work. I do realize this motor has a temp alarm however over the years my independent water pressure and temp gauges have saved me lots of headaches. The non-registering gauge keeps catching my eye even though I know it not hooked up. Any tips on the sender situation on this power plant would be appreciated.
