I will try and be as specific as possible when I describe this problem, so I apologize for the long wall of text.
My boat has (2) 2009 Yamaha F115 4-stroke outboards. Up until recently they both have worked flawlessly and have been maintained diligently to Yamaha spec.
About 3 weeks ago I tried to turn over the starboard engine and all I got was a simple click from the starter. Then nothing. The other motor continues to work flawlessly.
Here is where the confusion comes in, when I turn the key and hear the "click" at the starter, it kills all of the electricity in the boat until I turn the key all the way off.
Just to be clear, with the engine that is operating properly, even as I turn the key all the way to start things like the radio and fish finder remain on. When I turn the "bad" engine over they both turn off and do not turn back on until I turn the key to off, not just the run position.
Battery terminal connections are wrench tight, I've tapped the starter with a hammer, and everything else obvious seems to be normal.
As I mentioned, this happened a couple of weeks ago. After a few hours of me poking around the problem disappeared and I thought it was an anomaly. I had a few weeks of good boating up until now. Since the problem has resurfaced I want to attempt a real fix then just it randomly going away.
I will monitor this thread to give updates or reply to requests. I thank you in advance for the help.
