I know this topic has been covered because I have read them. I will try to explain what I have done and see if anyone else has suggestions.
My engine alarm goes off at idle after 5 minutes.
I have:
Tested the thermostats and they open and close at the appropriate temp.
Replaced the Poppit (Pressure Relief Valve)
Replaced the exhaust gaskets and cleaned out the manifolds.
Inspected the Water Pump (impeller) and it is only 10 months old and looks fine.
Tested both the primary and external oil tanks with an ohmmeter and they both worked.
Not sure what else to do. Any advice is appreciated.
I have:
