Can lower unit cause engine damage? This morning my motor seemed like it had a miss, a real severe, all of a sudden miss. I was out on lake and it wouldnt go in gear without killing and was running very rough. Then it wouldn't even run unless idle lever was revved way up; to get home I tilted up, got prop out of water, hit forward gear and got prop spinning revved up, and lowered spinning prop into water and made it 3 miles back to shore. That was the only way to achieve forward progress:get prop in air , high rpm, lower spinning prop into water. Once in gear and revved up it went 30 mph, but as soon as i idled down it killed w/ a nasty buck. It starts right back up but then kills w/ a buck. It seems like the lower unit or driveshaft is binding and killing motor???
Once on trailer seemed like a real bad miss, but then I heard a clanking seems to be coming from lower unit at same instant as "miss". Clank could be coming from powerhead, hard to isolate noise, but with plugs out engine spins freely and sounds normal so it seems crank/pistons are ok?? I drained carbs, changed plugs, motor starts instantly, has 140 psi compression all 3 cylinders, but at anywhere near idle rpms the engine bucks and kills. Even in neutral gear....... it seems like the lower unit is "killing" the engine w/ a clank.???
When I put motor in forward gear, engine off, the propeller will spin forward freely and make click,click,click,click,click sound, like one gear just missing another. Is this correct??? It will not spin freely backwards.
when I put in reverse, engine off, the prop wont spin freely either direction.
Any help will be deeply appreciated .
