motor starts & idles fine but has no power when you throttle up under load the charge coil tested bad so I replaced that and since then I've swapped out or changed all ignition components, carb is spotless, fuel pump looks good, checked fuel line and gas tank on another motor and that tests good as well what the heck is wrong with this thing could the exhaust be plugged? any ideas anyone?
