Hi.
I have as the heading says a 1993 v4 Yamaha with a slightly newer tachometer (from my 1996 75hp Yamaha)
But even with the color codes I cant understand how the electric part of the oil system is supposed to be connected.
Problem 1: As you see from the pictures I have the square plug harness with the green and green/red wire but no place to connect it in the engine.
Problem 2: the round 4-pin connection next to main harness have no matching connection.
Problem 3: The white/red cable from tach I understand is a V6 thing, and therefore not a problem, but where should white and blue go?
I have searced numerous pages on the internett but haven`t gotten a clear answer on how to connect or what adapter/harness to buy.
Any halp would be highly appreciated
Thanks in advance
Thanks in advance
