I recently pulled my flywheel off my DT50 due to seeing metal shaving flying out from under the flywheel while the engine was under 3/4 or more throttle. Once I pulled the fly wheel I could see where the magnets have been rubbing the mounting post for both the ignition and charging coils. There is barely any room for adjustment...what could I do to remedy this issue? My thoughts were to ream out the existing holes but I don?t want to mess up the air gap.
Here are some pictures:
I also noticed that the mounting post do no align with the bevel of the armature plate...is this correct?
