my 2001 yamaha 25 hp four stroke is leaking water and oil from the head gasket, there is also a hint of oil in the pee stream water, This would lead me to believe that its head gasket. Is my diagnosis correct, also does anyone know the torque sequence of this motor???? also recently my water pump went out and my overheat alarm went off, I'm thinking this may have been the cause, not sure. I believe the model is F25TLRZ or something along those lines. Any help would be much appreciated. thank you
