Bought this motor at an estate auction for virtually nothing. Owner had it stored inside on a stand, original gas tank and lines also professionally cleaned and stored. Got it home, checked compression, put new plugs in and no fire... Thought it was a bad CDI, but local mechanic said to unhook kill switch and try. BAM, nailed it. Fired right up and runs great. Now, for my question. I don't see any water coming out of exhaust port. I do, however, see water pumping out of lower unit at pivot joint. Not familiar with these motors at all, but im wondering if this is the correct dispersion point for the impeller or should it be coming out of exhaust ports? I don't want to damage it. If it needs a new impeller fine, but I'd like to be sure. Any help would be greatly appreciated!
