I have a Yamaha VXTRLY 225 ox66.. The oil from the sub tank is not getting to the oil tank on the motor. I checked the sensor in the tank on the motor as I slide the sensor up and down while monitoring the voltage at the sub tank... I get a constant 4.96 vdc. I can use the toggle sw and I get the 12 vdc to drive the oil pump to pump the oil to the tank on the pw head.. Maybe sensor?? CDI ??
Thanks for your help in the matter, I really appreciate it.
