Re: 1991 Yamaha 90 HP outboard water pump problem
You'll have to pry it up and off...probably stuck on the shaft from mineral/corrosion deposits. Worst case, you may have to cut it off. When you mount your new woodruff key and impeller, assemble everything with waterproof marine grease to help removal next time. Good Luck!
