cortlillard
- Jul 17, 2012
- 7
Hello all! I have searched the forums, and have not seemed to come up with an answer.
I have a 1984(?) 40HP Yamaha 3 cylinder 2 stoke outboard, and it seems to be mugging on one of its cylinders while warming up while in gear.
I can put it in neutral, and it seems to be fine, but while in gear, under load (in the water), it seems to not be firing on one cylinder. I have tested for spark, and that is good on all cylinders, the compression on all cylinders is good, I have cleaned the carbs thoroughly, and that does not seem to do it.
After warming up for approximately 10-15 mins, the engine very noticeably starts working properly, and the boat can get on plane.
I initially though i was burning too much oil, because i had some sludge coming out of the exhaust while testing it on land, so i reduced the oil to 75:1 from 50:1, I then tried putting premium gasoline in it to see if that would help, but that does not seem to be the issue.
I suspect that the carbs need to be tuned for proper fuel to air ratio, but i cant even tell which carb to tune, because i do not know which cylinder is having the issue.
I have no tach or any gauges for that matter. The engine is on a 1968 sea king, and I don't want to invest too much (either than time) into it.
