my motor was acting up on me and when looking at it i found the auto enrichment ground wire to be disconnected and the bolt is missing...ie worked its way loose......when the auto enrichment is not powered up does it stay in the on position?.....im running so rich that im getting black oil out of the exhaust under the cowl and by the prop>>>>>does this make sense?..............oh carbs are clean
