engine 7ymxm1602gc or possibly(go)
when switch turned on(not attempting to crank)no voltage reading at gauge.when trying to crank, only a click at the relay.when trying to trim,only click at relay
checked all fuses at the relays,cleaned and tightened battery terminals charged for four hours.....hit trim switch at engine,still only clicks at relays.
i jumped the starter with cables from my jeep and motor will turn over, and was able to trim engine down.
charged battery overnight, tried to trim at engine this morning and still only get a click at the relay, nothing from switch when trying to crank,and no reading on the volt gauge at dash.
i put battery under a load test 560 cca, and get a 10 volt reading under load, which according to fella that tested it should be okay.
btw, lights work and horn works.
thanks in advance for any help.
ronnie
ronnie
