I purchased a 2005 G3 with a 2005 60hp TLRD about one month ago & I finally have it running nicely after recleaning the carbs & blowing out, changed prop, lower motor to the #1 hole - stopped ventilation. The only slight problem i'm having is when running wot or 3/4 throttle and I start backing off of the throttle at about the 1/2 throttle, I get a surge where the engine speeds up.....i keep backing off the throttle & everything is fine, it starts up & runs fine except for this problem. Does anyone have any ideas?
