1996 Suzuki jet
Matt-K
Is there any place too get 3500' jets for the carbs, I an in Idaho and run tie motor from about 2500' too 5000' and I need jets for the altitude in between, thanks
Matt
Matt-K
Re: 1996 Suzuki jet
Well sharpened the impeller and moved it out 4 shims, should be good too roll now, just need too find different jets for those carbs.....
Matt
mphelle8vld
Re: 1996 Suzuki jet
You don't say what motor you have, Brownspoint Marine is a good source for Suzuki parts. 4 shims at once? must have been really worn.
Matt-K
Re: 1996 Suzuki jet
Yea it was alittle more worn than I originally thought, straightened the grates also too help the air bubbles from going in, and it is a 140 hp jet drive 2 stroke with 4 carbs is that what your talking about?
Matt
