dickjustice
- May 3, 2012
- 10
I recently purchased this motor to replace a 75 hp force that had a cracked block for a 25 ft pontoon boat. A shade tree boat mechanic found the engine for me and I let him install it. Of course I was assured that the motor would run fine, but when I took it out for a test drive the new to me motor did not seem right. First, the motor cranks and idles like a champ and accelerates to half throttle fine but when I continue on past half throttle there is not a difference in performance. I checked the throttle linkage to make sure that it was opening up the carbs past half throttle and it seemed to be operating fine. Needless to say, but I was very dissappointed when the new motor with 10 more hp was actually slower than my old motor only running off of 2 cylinders. I am going to change the fuel filter this week and run a can of seafoam through it. Anybody got any ideas where I should start checking if its not the fuel filter. It seems to me that its not getting enough fuel.
