Hi Folks,
I have alot to cover, but I'll keep it as short as I can. I recently bought a 1984 suzuki Dt-30 Serial # 03001 410335. It is both electric and pull start. The motor was brand new. It had zero evidence that it ever ran. It came with the original 6 gallon metal can that never had gas in it before. Also included was the original fuel line with primer bulb. All the lines are soft and free of any cracks or dry rot. I rigged it on a boat with a new battery, and it ran like a dream. Ran it about 15 miles with no problems. Refilled the tank, 50:1 and went to go out the next day, and it idled kind of ruff. Took it out, and it acted like the plugs were fouled on initial take off. It smoothed out with more throttle, but at about 3/4 throttle it started sputtering. Took it back to the dock and found the plugs were fouled. Bought some new plugs and it ran good for the first minute of so and did the same thing. Plugs were wet, and black. It is getting worse to the point it doesn't even want to run. Any suggestions on even where to start with this one?
