elverhunter
- Jun 10, 2012
- 7
Hello, I am new to site
I have 1998 Yamaha 130 TLRW V-4
Can someone give me some Idea what is problem on my outboard?:
One day, I'd put my boat in the water and took off after few minutes(@ 3000 RPM) I've got an alarm
No indication on Digital gauge After slowed down to Idle alarm stopped in couple of minutes later
I'd repeated and samething again
So, Loaded up and headed back to Home
Few days later I'd changed water pump Impeller(By local marine shop) and instaslled new thermostats
After verified Oil tank sensors and switches were OK
Ran again with garden hose @2400 RPM Alarm again,
soon as alarmed I took cover off and put my hands on the engine where thermo,s are locate
Portside was much Hotter then Starb. side So, I un-plugged Temp sensor on Portside and alarm stopped
Then I was thinking, Mmm- must be build up in the water jacket
I took cover off also Cylinder head as well to clean it, It wasn't bad almost very clean
any one have any Idea what I need check next?
