Suzuki df140 2001. The temp light just started to flash. Both the pump impeller and the thermostat were done in the beginning of the season and the boat was used a number of times with no problems till now. The engine is actually a good temperature tested with my temp gun so it is not actually overheating and the light will flash with the key on engine not running position. It will flash in that position even if the engine is cold like if it has been sitting over night.
I'm thinking a sensor is bad but figured I would come here to get other opinions and maybe a way to test it out. Thanks in advance.
