i have a suzuki dt30c,1988-97, oil injection,2 stroke, 3 cylinders thats been services and ran about 5 months ago...i,ve now put it back on the boat and connected every up..my engine seems to do everything but start..when i prime the fuel bulb a few times the fuels seems to leak from the connection into the outboard..like there,s an obstruction...i,ve discconected the fuel line in different places to see if theres a blockage, fuel comes out after the fuel filter and if i open the bleed screw at the bottom of the carburator i get a drip of fuel,so keep thinking its to do with the float of needlr values which should be clean due to the service i think...the outboard trys to start but still does,nt seem to get the fuel is needs
a) i,ve check the spark plugs...which are fine...
b)i have good compression in all cylinders...
c) fuel is new
Is there anything else i can trybefore dismantling the carburator.. or am i missing something really simple..i have a engineering background but know very little of outboards in general..any help would be appreicated folks
p.s ..this might be a stupid question but when i bought this outboard , i was told just to fill it when normal fuel..am i right in thinking that the oil injection add the oil automaticaly...or should i still have a normal 2 stoke fuel mix..
c) fuel is new
