Dont know if anyone has any ideas but heres my problem(s):
The exhaust plug corroded away and a portion blew out ( of the exhaust plug) when motor was running. I was able to come up with a plug to repair that but the high heat exposed the wiring harness that runs past that area (left side of motor just above flush out plug) and melted the wires together. at first the motor would not start. Then after I was able to separate the wires,took a long time and i had to use a razor, it started but ran real rough. I can smell fuel and it appears to be coming out of the bottom of the lower unit (thru the exhauset ?) i am also getting a "fault code" of 4 then 3 (lights blinking). The fault code i looked up indicated fuel injector. I am confused as to what happened and know it must be related to the wires having melted together. If anyone has any ideas i would greatly appreciate the help.
dan
dan
