Hi there.
Hope you can make sense of what im about to type lol
I just bought an old 28hp Yamaha for my first boat. It is electric start & ive used it now 6 or 7 times & it starts & runs like a dream.
Only problem is,, When its runnin, there seems to be alot of excess movement from the engine where it mounts on top of the upright shaft. Even when it is switched off,, when i put my hand on the front of engine cover & i push,, engine moves slightly back & forward with a little play. Ive it linked up to cable controls & again when its running & i push my hand against cover,, the engine revs a little more, & its the excess play that making it pull a little on the throttle cable. Its making the engine shake about on its shaft at idle.
Is there a bushing i can replace where the engine attaches onto the top of shaft or any way i can tighten this up? Ive tried tighening the adjustable screw under the engine but his just makes it harder to steer & doesnt help in gettin rid of the excess movement,
Hope im describing this in an understandable way, but to summarise, Where the hinge is that the engine pivots on to steer right & left seems very loose.
Any help or advise would be very much appriciated.
Thanks guys
Thanks guys
