getbuckedup
- May 23, 2012
- 1
i have a either 87 or 88 suzuki dt75 which had water pump go out after replacing that so proper water flow was restored noticed temp. sensor had half melted and water was shooting out so fixed that and now found low compression on top cylinder my mechanic said its most likely the piston rings melted and broke apart so i am going to attempt to pull piston and check cylinder myself. i have very little boat motor experience and was wondering if someone on here can help me out with the steps to pull the piston and change rings because all the work and parts got too expensive to keep having mechanic do work thanks in advance
