Jonathan Suzuki 70df
- May 22, 2012
- 1
My motor will not trim up and trimming down works great.
I have checked both the switch on the throttle and engine and they are fine.
I have checked continuity on all wires and it is all good.
There is no clicking or any sound when I try to trim up, but the down works perfectly.
The only spot where I do not get continuity is on the PTT motor relay between the blue (up) wire terminal and the power terminal (coming from the starter motor relay). Does this mean I have to replace the "up" relay?
