I recently installed a second hand 2000 100hp Yamaha 4-stroke on my runabout and ever since the install it seems to be dropping a cylinder and running on three instead of four. When I purchased the motor I went over it with a fine tooth comb and took it for a rigorous test drive, during which it did not have this problem. Before I installed the motor I had it serviced by a dealer who indicated that everything was great on the motor and it should be a runner for many years to come.
Now that I have it installed, when it comes under load while trying to plane, it appears to drop a cylinder and the motor bogs a little bit, doesn't cut out but changes pitch and loses a little bit of power. It sounds/feels like it picks the cylinder back up intermittently while planing and once on plane it will generally pick it back up and run fine unless I hold it wide open, at which point it seems to drop the cylinder again. This problem gets worse when the boat is loaded down and never does it at idle.
The motor isn't cutting out completely by any means, it changes pitch and loses a little power. If I push the throttle quickly it will bog a little, but it seems most times when I apply the throttle steadily it doesn't do it as often.
It does not appear to be a fuel problem as I have gone over the whole system replaced filters and feeder tubes.
Does anyone have any suggestions, to me this sounds like a spark plug may be pooched or on the way out...any other thoughts would be greatly appreciated.
-Go Blue Jays!
-Go Blue Jays!
