Re: how to remove trim motor 1998 Yamaha 225 salt water series
Unscrew the manual release valve and tilt the engine up as far as it can go. Unbolt and remove the tilt and trim unit. A bit of wiggling/jiggling required but it will come out.Once its out replacing the trim motor is easy. I just did this yesterday and am in the process of doing the trim cylinders right now.
