jawbreaker23
- Jan 31, 2012
- 4
i have a 2005 f225 yamaha. when i turn the ingnition switch to start the starter does not engage the flywheel. i switched the starter with my twin and the good starter does the same thing and the problem starter works on the twin. i bypassed the battery switch and get the same results. switched the battery from the known good motor and get the same results. i switched the relay that is attached to the starter solenoid with a brown and white wire and get the same, relay is known good on twin. power drops at starter when ign is in the start pos to approx 6v. dont know where to look for bad grds on the engine can any help?
