hey everyone, ive got a question about disconnecting my oil injection..i believe i know how, but i want to make sure everyone agrees that its safe..i attached a pic to ease the description..
as you can see in the pic, ive drawn arrows and labeled certain lines as what they are, and were they flow to..from right to left, ive labeled FTM as fuel to motor, then fuel from the tank, and finally the oil injection line. what i want to know is, can i simply just cut the oil line in half, and put bolts or some other object to block the flow, and then just mix my gas?
i want to do this because what ive read the injection system runs the motor at 100:1, and i want to run it at 50:1 because i think it would be better for the motor.im not worried about mixing my gas wrong or anything..ive owned 2 strokes my whole life so im use to mixing gas and oil..thanks everyone!
