Just purchased a 1995 Suzuki 3 cyl. short shaft tiller with manual and electric start. After initial inspection the engine was started and run on a hose, shifted and so on for me. Initially the engine started with a high idle then idled down to a nice smooth idle. That was on Friday. Took the boat to the lake today (Sunday) for some fishing and the engine never idled down at all. Stayed up around 1200-1500RPM. The engine appears to be running cold and not warming up at idle. I did check the idle stop screw and it is backed off (plus the engine had already idled down at least once). Am thinking there must be a connection to the engine not warming, thinking that the engine should reach a certain temp then idle down? Thanks in advance for any help.
