1989 yamaha 150 precision blend excessive oil in sub resevoir
THEMAGIGMAN
I have an 89 yamaha 150 and i have an excessive amount of oil comming from air intake. I also noticed my sub-oil tank was overfilled. So i put 2 and 2 together and figured out the oil was draining into the intake from a hose connected to the oil tank. The question is why the extra oil in tank. I noticed an emergency oil switch which pump reserved oil into tank, but the switch itself was broke. i don't know if that is the cause or if a sensor in oil tank may have gone bad. if anyone has any ideas it would help me a lot thank you.
R Socey
Re: 1989 yamaha 150 precision blend excessive oil in sub resevoir
Welcome: sounds like it might be the sensor or the emergency switch is stuck on the fill position. I would replace the switch, and see.
THEMAGIGMAN
Ok thank, thats what i was leaning towards. I wanted to just replace both but its a $400 bill so if you have any testing ideas it would be great thanks again for replying
