I have a 1994 Yamaha 25 hp 2 cycle #C25ELRS that I've only owned a few months. I started the motor today with muffs and noticed the tell tale was not streaming water, nor was the return hole, just below the transom bracket on the front of the motor, if that's the correct term.
I shut it down, re-positioned the muffs, tried again with same results. Third time the tell tale and return both started putting out water. I figured the thermostat had not opened. I ran the motor for a few minutes and all was fine.
Then I read here tonight after doing a search that the thermostat would not affect the tell tale. I guess my question is-does it take a few seconds from a cold start to pick up water and start putting it out?
