johnnybahama
- Jan 26, 2012
- 20
New patient, s130txrw, Motor running fine when turned off. When they tried to start a week or so later the engine had seized. I pulled both heads and discovered that the head bolts had loosened on the starboard side, or so I think as the gasket was still intact, and #3 had saltwater in it. I tilted it up and soaked it with decarb and was able to free up the piston. I've been working it around and am trying to clean out the rust and salt crystals. The piston is still a bit tight when it comes up past the exhaust port and is leaving some salt and rust residue. I am continuing to soak with decarb rotate the crank. What should I do to clear the rest and free the rings. If possible. Your input would be greatly appreciated. Thanks, Jon
