1998 Century 2300
- May 14, 2011
- 6
My 200hp OX 66 boat motor is surging erratically. I know there are several post about this same problem, but didn't see any solutions. It was only doing it at higher RPM's and then it kept getting worse and doing it at lower and lower RPM's until it shut off. I immediately restarted it and then it gave me high RPM's again for a few minutes and then got worse again. If it provides any more info, it tended to do it more when I hit a wave and the momentum of the boat was slowed. Obviously a fuel problem, but not sure where to check. Fuel water seperator looked good as well as the clear filter on the motor. Where is this rvt filter other threads are talking about? ????
Thanks
Thanks
