I have a 1994 Yamaha 25 hp #C25ELRS that has run fine until today. It started right up at first, then died out and would not "hit a lick". Finally took the plugs out and they were wet with gas. I let them dry, replaced them and it ran fine. This happened two more times, although I only pulled the plugs once more.
After that it, it started fine. Just touch the starter and that was all it took. The motor ran all through idle to wide open fine when it was running.
Could it have been trash in the fuel? I was lucky today, way up the river, but had friends in another boat that could give me a tow. I might not be so lucky next time.
Thanks,
John
Thanks,
John
