waterMatt
- Dec 17, 2011
- 1
I'm new here so hello to all boat enthusiasts!!
I disassembled DT8 1987 and I see issue with oil seals (some oil and some water in gear case). Part no: 11
1987 DT6 Suzuki Marine Outboard GEAR CASE Diagram and Parts
The bearing carrier has two of oil seals. What is the best way to change them if the external diameter of seal is bigger then the hole in bearing carrien from propeller site or bearing site.
Other thing is about how to remove part no: 18
1987 DT6 Suzuki Marine Outboard WATER PUMP Diagram and Parts
to get to oil seals? It's very stubborn and looks like 20 years of use in salt water, saying in one world is welded. Would submgeing in breake fluid or parrafin oil for week help??
Thanks in advance for any of your help or direction!!
