Blake0912
- Oct 31, 2010
- 310
I have a 2001 Yamaha 90hp that I have been having an electrical problem with, first when I turned the key nothing would happen but the TnT would work, but now nothing will work it just clicks when the TnT switch is used. I took a volt meter to the starter relay (part #16 in link below) and was not getting power on the out side of the relay so I figure that is causing the issue. Stupid me forgot to write down what wires go where when I took the part out. So my question is can anybody with a similar motor take a pic or tell me what wires go where. I know where the POS line from the battery goes and where the POS line to the starter goes my problem is I have 2 other wires a smaller one coming from the front of the engine and a 2nd one coming from the relay assembly(Part #40). I think the small wire goes on the same terminal as the POS coming from the battery and the wire coming from the relay assembly goes on the same side as the POS wire leading to the starter. But I'm not 100% sure and dont want to cook my new relay if I hook them up backwards.
Thanks in advance.
Edit*
Guess it wont let me post a link from another web site, the diagram I am talking about is from ********** and its a 90TLRY model
(sorry if I'm breaking a forum rule by mentioning another website I just cant find a diagram on Iboats)
Thanks in advance.
Edit*
