I have a 2005 150D yamaha outboard and the problem is that oil will not refill from the remote tank to the main tank on the motor either electrically or manually using the switch on the motor. I have removed the tank, cleaned it and changed the small inline filter on the outside of the remote tank. Still no oil being pumped to the main tank on the motor. Is there some electrical connection or fuse that I am not checkingor could it be the oil line itself that is blocked.
